"A chunk of timing chain"
Not laughing, just appreciating the experience.
So the whole front of the engine comes off. Pain in the ashtray job.
You are going to have a lot off, so I will mention all that would be nice to go back on, and best options. If you cant put that much $ into it now, what is your budget so we can recommend best to do now.
Rent a harmonic balancer puller/installer- DO NOT use the bolt to reinstall.
Buy: new front main seal I like timken, felpro,
Get time keeper timing gears from Leroy
The new chain will strech out in 30k miles.
Waterpump will be off. Good time to replace- upgrade to balanced flow if you haven't already.(even if you dont alter thermostat crossover now)
Harmonic balancer and belt drive pulley are only good for 100k miles- too long will break crankshaft. Leroy agsin for fluidampr balancer and Leroy custom billet pulley so they are good for ever like the timing gears.
If not AC Delco (or GEP) parts only here.
New serp belt when it goes together also.
Basically, I bring engine to #1 tdc. Pull battery neg cables, and pull off every accessory mounted to the front of the engine. Just lay a/c and steering pump to side without undoing hoses (some years not possible, but no clue what you have.)
Remove balancer, waterpump, timing cover.
Spend half million on parts and reassemble.
I believe in stickies is manual showing timing gear marks for installing proper and all torque specs. If not I will dig up my manual and take pics for you.
Ok everyone- what did I miss?
