Maximum Effort
It looked familiar, I had to do some google action to see. Thats not one of the 4 clyinder shut off ones is it?
I'm not sure. I know some had the 4 cylinder idle option while some of the later ones didn't. I will have to see. I have no idea what it came off of or year other than the motor. I'm sure I can disable the 4 cylinder idle somehow if it does have one.
No, the motors were not high output. Fuel rate stock is about 70cc's. So slightly above a stock DB2831-4911. However, this can be ramped WAY up from there. I am only looking for a fuel rate in the 110-130cc range. So not very much more. The pump should be more than capable of it and grow as I build if I need more.
  • Like
Reactions: NVW
A couple decades back we had a neighbor with an IH 1468 that had the original tractor (idle on 4 cylinder) version pump. They had the pump modified to always run on all 8 - believe by a pump shop in NE IA called Dubuque Injection Service that had some experience with that pump. Tractor didn't always come back to 8 fast enough & would occasionally die if load came up faster than fueling to 2nd 4 cylinders could catch up.
If memory serves, there were some differences between the truck & tractor DV550 pump governor systems? Might be worth a call to that pump shop? Don't know how common experience with that pump will be. Relative to the P pumps?
Wonder if the DV550 truck engines were red like IH tractor engines since pump is red?
I know the governors are different. Has an AG governor on it now, and will have to be switched. Either to a K-style governor or something custom. My pump guy is gone to a convention this week and knows some old timers that are good with these things. Gonna get some info this coming week hopefully
Do I see another Readers Rides entry coming from you if this critter works out and you can push near 400 hp at the crank with it?
Haha Oh I bet I could slide another article into Diesel Power lol speak of the devil, I was just reading that article yesterday on the throne. It's sitting about 4 feet from me as I type this lol
I remember well. I have every issue back to Vol. 1 No. 3. So, are we to infer that you just typed your response while seated upon your throne since the article is 4 feet away?
I have a flip phone. Indestructible, but let's just say it isn't the most entertaining thing to take into the throne room. Computers are a lot nicer lol
