iamdave0887
Here Comes Chaos.....
i'm doing a manual glow plug over ride setup that uses a relay and a pushbutton for the low side of the relay. i found the relay below in my garage.
the photo is also used for size comparison against the soda can.
it was the relay for a starter on a tractor with a 20hp v-twin OHV engine. can i use this relay for my over ride? i plan on using 4 awg(it was lying around) for the high side of the relay. 10 amp fuse for the low side and i have a maxi fuse holder for the high side but i'm unsure if a 50 amp fuse will be enough. thanks all.
