97duallydiesel
Ok . The other thread was getting to long and I determined the problem with my lift pump not working was a faulty ground going to the pump. I ran a jumper cable directly to the negative post and it works fine now..:thumbsup:
HOWEVER , the real issue know is : We had a good snow storm two sundays ago. I plow for the state and the truck was running great up until around the 16th or 17th straight hour of running /plowing /idoling. I was at a set of lights and the truck just stalled ,luckily I was able to steer it into a parking lot and after several minutes it started right up.
It ran ok for the next 6 to 7 hrs until I parked it. The next day it didn't stall but had issues . Thru first and second gear it was running strong but when it got to third it would bog down then die./stall. This happened numerous times in the next three days so I thought it was a PMD issue. I ordered a relocator kit with PMD , harness and heat sync from Pensacola Diesel.
Yesterday , after mounting the PMD and running the truck for a test drive I came back to the house to attach my plow and the truck sputtered ,revved from 600RPM up to 1200RPM then died. This is when I went thru the process of the LP malfunction ( See other Post).
Sorry this is so long but it's the only way to describe it.
Ok LP is fixed and I take it out for a test drive . Runs like a Raped Ape :thumbsup:So I think all is well..until..I get back home and the same thing happens as before it revs bucks then dies . :mad2:
I had enough for the night so i leave it until morn. I had to work today and drove the truck ,after letting it warm up for 10-15mins , approx. 10 miles to work . At around the 6-7 mile mark the truck starts to buck and loose power blowing black smoke ,I was able to get it to work and left it there until I went home.
The same thing happens on the way home however it stalls 3 times . The truck can sit idolling forever however when it gets up to running temp around 190' this happens..
So when I get it home unplugged the new relocated PMD and plugged in the old IP mounted one. It runs fine until it gets up to the temp while driving...
The sending unit,fuel line,fuel pump (twice),fuel manager and filter where changed 3 months ago . I didn't do most of the work and I spoke to the Mechanic who did about the tank condition . He told me it has some exterior surface rust but was ok.... Please help .. another storm is coming tomm and I can't afford for this truck to sit....
