dieselkidd04
Just recently had my allison go into limp mode due to loss of fluid, inspected and found that there was a crack in the low/reverse housing on the rear of the trans and it was spitting fluid everywhere, began teardown, removed housing, and planetary gearset, but now that im trying to re-install the housing it wont go all the way flush with the trans, something is binding,ive r&r both planetart gearsets and output shafts and also the friction and metal plates and found nothing misaligned im at a loss with this and idk if i should pull the trans or not.
please help!!!!!!!!!!!!!!!!
