nealpellecchia
I'd like to see the result of some glue in the cracks. If that's impossible why are they allowed to market it.
Yeah GM stuff I got, tablets, is said to be like the bars stop leak I put in years ago to stop a heater core leak. Clogged the rad had it rodded out still may be clogged a bit.yep, sounds like a head crack.
Hopefully you have not added sealant yet, it will clog up a radiator and heater core.
The rad...iatorthe cost to have it rodded would have went a long way towards a good head or head gaskets.
C'mon man, give the truck what it deserves!![]()
I did my wife's v6 pinto. Both heads cracked between the valves. Cheap easy.Runs too good. Once apart, if it's a lot,p may go to the junkyard like that. Why these are recommended GM tablets dude! Lol.
Wow, great reads.When I get as a Mac tools guy a few years back, I went into a gmc dealership and saw a tech cutting up pieces of foam like used in seats. A walked by him 2 minutes later to see him packing it in behind the glass of the side mirror. A couple days later at a Chevy dealership another tech did the same thing so I asked him- that is the factory approved repair for a vibrating mirror in gmt800 trucks.
I asked the Chevy guy about doing that to my suburban when it starts having the problem and his response was "Heck no, Will. Take it apart and fix it the right way- this is one of a million jury rig fixes from GM to save $ under warranty."
Maybe he was wrong, he has only been a Gm tech since he was 20. I brought him a birthday cupcake on his 65th about a month after the mirror fix.
Figure it out, if they pinched pennies building it the first time, why would they do something the best way later under warranty?![]()
