Found this at a neighboring site.
):h
#04039B: Special Coverage Adjustment - Injectors-Replace - (Nov 19, 2007)
Subject:04039B - Special Policy Adjustment - Injector - Replace
Models:2001-2004 Chevrolet Silverado
2001-2004 GMC Sierra
2003-2004 Chevrolet Kodiak
2003-2004 GMC TopKick
Equipped with 6.6L Duramax Diesel (RPO LB7 - VIN Code 1) Engine
THIS BULLETIN IS BEING REVISED TO ADD 2004 MODEL YEAR TRUCKS. PLEASE DISCARD SPECIAL POLICY BULLETIN NUMBER 04039A, DATED OCTOBER, 2006.
Condition
Some customers of 2001-04 model year Chevrolet Silverado; GMC Sierra; 2003-04 Chevrolet Kodiak and GMC TopKick vehicles, equipped with a 6.6L Duramax Diesel (RPO LB7 - VIN Code 1) engine, may experience vehicle service engine soon (SES) light illumination, low engine power, hard start, and/or fuel in crankcase, requiring injector replacement, as a result of high fuel return rates due to fuel injector body cracks, ball seat erosion, or high pressure seal extrusion (refer to Corporate Bulletin Number 04-06-04-007G and SI).
This special policy covers the condition described above for a period of 7 years or 200,000 miles (320,000 km), whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership. The repairs will be made at no charge to the customer.
Important: This special policy only covers the above noted failure modes, which are identified by high fuel return flow.
For 2001-2002 vehicles covered by Vehicle Service Contracts, all eligible claims with repair orders on or after May 25, 2004, are covered by this special policy and must be submitted using the labor operation codes provided with this bulletin. Claims with repair orders prior to May 25, 2004 must be submitted to the Service Contract provider.
For 2003 vehicles covered by Vehicle Service Contracts, all eligible claims with repair orders on or after October 10, 2006 are covered by this special policy and must be submitted using the labor operation codes provided with this bulletin. Claims with repair orders prior to October 10, 2006 must be submitted to the Service Contract provider.
For 2004 vehicles covered by Vehicle Service Contracts, all eligible claims with repair orders on or after November 19, 2007 are covered by this special coverage and must be submitted using the labor operation codes provided with this bulletin. Claims with repair orders prior to November 19, 2007 must be submitted to the Service Contract provider.
Vehicles Involved
Involved are
all 2001-04 model year Chevrolet Silverado, GMC Sierra; 2003-2004 Chevrolet Kodiak and GMC TopKick vehicles equipped with a 6.6L Duramax Diesel (RPO LB7 - VIN Code 1) engine and built within the following start of production to end of production VIN breakpoints:
Year
Division
Model
From
Through
2001
Chevrolet
Silverado
1E100028
1E346644
1F100001
1F213872
1Z100015
1Z100019
2001
GMC
Sierra
1E100021
1E346642
1F100010
1F213864
2002
Chevrolet
Silverado
2E100009
2E306435
2F100004
2F247804
2002
GMC
Sierra
2E100003
2E306345
2F100011
2F247974
2003
Chevrolet
Silverado
3E100002
3E381007
3F100003
3F259043
2003
Chevrolet
Kodiak
3F500015
3F522532
2003
GMC
Sierra
3E100003
3E381124
3F100008
3F259040
2003
GMC
TopKick
3F500001
3F900945
2004
Chevrolet
Silverado
4E100018
4E221395
4F100004
4F174846
2004
Chevrolet
Kodiak
4F500118
4F510079
2004
GMC
Sierra
4E100002
4E223355
4F100008
4F174834
2004
GMC
TopKick
4F100126
4F510077
Parts Information
Parts required to complete this special policy are to be obtained from General Motors Service Parts Operations (GMSPO).
Part Number
Description
Qty/ Vehicle
97729095*
Injector Kit, Dir Fuel (Incls: Injector, Gasket, Seal)
8
97188896
Gasket, Valve Rocker Arm Cover (Reusable Gasket)
As Req'd
97228933
Gasket, F/Injr Fuel Return Pipe
8
97600925
2
94011604
Seal, Water Outlet
1
12378521 (US)
88901148 (CN)
Sealant
As Req'd
97188463
Housing, F/Injr Noz
As Req'd
94051259
Seal, F/Injr Noz Hsg (O-Ring)
As Req'd
*P/N 97729095 is only available in a merchandising pack quantity of 4. Current order restriction limits availability to 8 injectors per VIN.
Customer Notification
Customers will be notified of the special policy on their vehicles by General Motors (see copy of typical customer letter included with this bulletin -- actual divisional letter may vary slightly).
Service Procedure
Refer to the latest version of Corporate Bulletin Number
04-06-04-007G and
Service Information to perform diagnostics and fuel injector replacement for high fuel return rates.
Courtesy Transportation
The General Motors Courtesy Transportation program is intended to minimize customer inconvenience when a vehicle requires a repair that is covered by the New Vehicle Limited Warranty. The availability of courtesy transportation to customers whose vehicles are within the warranty coverage period and involved in a product recall is very important in maintaining customer satisfaction. Dealers are to ensure that these customers understand that shuttle service or some other form of courtesy transportation is available and will be provided at no charge. Dealers should refer to the General Motors Service Policies and Procedures Manual for Courtesy Transportation guidelines.
Claim Information
For vehicles repaired under the terms of this special policy, submit a claim with the information indicated below:
Important: A copy of the completed TSB 04-06-04-007G diagnostic worksheet and other required documentation (e.g. Tech 2® snapshots) must be included in the box with the returned injectors.
Repair Performed
Part Count
Part No.
Parts Allow
CC-FC
Labor Op
Labor Hours
Net Item
Refer to the latest version of TSB 04-06-04-007 to diagnose and replace all 8 fuel injectors
MK-95
T5603
Silverado, Sierra
8.0
Kodiak, TopKick
9.7
Reimbursement for Previous Repairs (Canadian Dealers ONLY)
N/A
N/A
N/A
MK-95
T5604
0.2
Administrative labor hours
N/A
N/A
N/A
MK-95
N/A
* -- The "Parts Allowance" should be the sum total of the current GMSPO Dealer Net price plus applicable Mark-Up or Landed Cost Mark-up (for IPC) for injectors needed to complete the repair.
** -- The amount identified in the "Net Item" column should represent the sum total of the Current GMSPO Dealer Net Price plus applicable Mark-Up or Landed Cost Mark-Up (for IPC) for shop supplies needed to perform the required repairs.
*** -- The amount identified in the "Net Item" column should represent the customer reimbursement amount.
**** -- Submit courtesy transportation using normal labor operations for courtesy transportation as indicated in the GM Service Policies and Procedures Manual.
***** -- The amount identified in the "Net Item" column should represent the actual dollar amount for courtesy transportation.
Customer Reimbursement -- For US
All customer requests for reimbursement for previous repairs for the special policy condition will be handled by the Customer Assistance Center, not by dealers.
A General Motors Special Policy Customer Reimbursement Procedure form is included with the customer letter.
Important: Refer to the GM Service Policies and Procedures Manual, section 6.1.12, for specific procedures regarding customer reimbursement and the form.
Customer Reimbursement -- Canada
Customer requests for reimbursement for previous repairs to correct high fuel return rate by replacing fuel injectors in 2004 model year trucks are to be submitted prior to or by November 30, 2008. Repairs must have occurred within the 7 years of the date the vehicle was originally placed in service, or 320,000 km, whichever occurs first.
When a customer requests reimbursement, they must provide the following:
• Proof of ownership at time of repair.
• Original paid receipt confirming the amount of unreimbursed repair expense(s) (including Service Contract deductibles), a description of the repair, and the person or entity performing the repair.
If the work was done by someone other than a GM dealership, the amount of reimbursement will be limited to the amount that the repair would have cost GM to have it completed by a GM dealership.
November 2007Dear General Motors Customer:
As the owner of a 2001-04 model year Chevrolet Silverado or GMC Sierra or 2003-04 Chevrolet Kodiak, or GMC TopKick vehicle, your satisfaction with our product is very important to us.
This letter is intended to make you aware that some 2001-04 model year Chevrolet Silverado, GMC Sierra; 2003-04 Chevrolet Kodiak and GMC TopKick vehicles, equipped with a 6.6L Duramax diesel engine, may experience vehicle service engine soon (SES) light illumination, low engine power, hard start, and/or fuel in crankcase, requiring injector replacement, as a result of high fuel return rates due to fuel injector body cracks, ball seat erosion or high pressure extrusion. Symptoms of these conditions include illumination of the service engine soon (SES) light, low engine power, hard start, and/or fuel in the crankcase.
This is not a recall. Do not take your vehicle to your dealer as a result of this letter unless you believe that your vehicle has the condition as described above.
What We Have Done
General Motors is providing owners with additional protection for the fuel injectors. If this condition occurs on your 2001-04 model year Chevrolet Silverado, GMC Sierra; 2003-04 Chevrolet Kodiak or GMC TopKick vehicle within 7 years of the date your vehicle was originally placed in service or 200,000 miles (320,000 km), whichever occurs first, the condition will be repaired for you at
no charge . Diagnosis or repair for conditions other than the condition described above is not covered under this special coverage program.
What You Should Do
Repairs and adjustments qualifying under this special coverage must be performed by a General Motors dealer. You may want to call the service department at your dealer to find out how long they will need to have your vehicle so that you may schedule the appointment at a time that is a convenient time for you. This will also allow your dealer to order parts if they are not already in stock. Keep this letter with your other important glovebox literature for future reference.
Reimbursement
The enclosed form explains what reimbursement is available and how to request reimbursement if you have paid for repairs for the special policy condition.
If you have any questions or need any assistance, must contact your dealer or the appropriate Customer Assistance Center at the number listed below. The Customer Assistance Center's hours of operation are from 8:00 AM to 11:00 PM, EST, Monday through Friday.
Division
Number
Text Telephones (TTY)
Chevrolet
1-800-630-2438
1-800-833-2438
GMC
1-866-996-9463
1-800-462-8583
Puerto Rico - English
1-800-496-9992
Puerto Rico - Español
1-800-496-9993
Virgin Islands
1-800-496-9994
GMICT
1-800-862-4389
We are sorry for any inconvenience you may experience; however we have taken this action in the interest of your continued satisfaction with our products.
General Motors Corporation
Enclosure
04039B
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
__________________
