Dunedain15
Active Member
Here's my sad tale:
My mileage dropped significantly during my last tank (15.5 down to 13.4). I've had some other performance issues that point to the IP, but I didn't want to replace it while I had the stock lift pump/fuel filter sock. So, I ordered the Walbro lift pump/NAPA fuel filter from LeroyDiesel.com. That was last Friday. On Saturday, I was helping my aunt move and was pulling a small trailer. I was about to turn left at a light, and, when I hit the gas, the truck shut off. I cranked and cranked and cranked, but there was no fuel getting to the engine. We got to the side of the road, and I loosened the cap on the fuel filter while my wife turned the key to the ON position. This has always activated the lift pump previously. No fuel came out. "Great," I thought. "That part's already on the way. Good time for it to die." Got it towed, put the new filter and lift pump on last night, and the pump still doesn't run when the key is ON. I ran 12V straight from the battery to the lift pump, and was able to bleed the air out of the system that way. Fuel came out of the FFM. Plugged it back into the harness, and nothing.
So, what do I check next? It's my understanding that the ECM controls the LP until the engine is running. With that in mind, I'll be picking up a fuel pump relay on my way home today. But I wanted to see what else you guys thought. Truck details are below. Thanks in advance.
