weldguy
SO I have been reading the various duramax forums for several months now as that is how long I have been dealing with my issue. I did land on this forum to post though ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Truck: 2003 GMC 2500HD with muffler delete and banks 6-gun 132xxx miles, GM injectors at 70K, replace #3 and #7 at 120K
Long story:
Last March, I was driving my truck hard and as I slowed down for the corner, it started running rough. Then missing, and blowing black smoke. Plug in with my Foxwell scan tool and it reads all zeros for balance, and 1mm3 or less for fuel rate. Was able to figure out that means injectors are stuck open and the ECM threw its hand in the air. Bought some Standard Motor Product reman injectors because the had a 3 year warranty (insert Tommy Boy warranty skit). Fast forward a couple months before I could find someone to work on it since the reputable diesel shop in Michigan is several hours away, and I now have no tow vehicle. I found that the local injection shop guy does swaps on the side - perfect. He did the swap and one injector is junk out of the box. He replaced that one with one of his Bosch remans. He put it back together and it had a fuel knock - no biggie he said, leaky injector.
Drive it, and research is telling me injector knock is very bad. But, it also BELLOWS white smoke, spits and sputters from about 165 ECT to 175 ECT, via the dash gauge. I have not been able to scanning while it is doing this, so i do not have good details.
I have trended fuel pressure, and it generally follows, but is probably more than the 150 psi that I believe is called out for replacement. Balance rates are: Cyl 1: -1.9 to -2.1, Cyl 2: .5, cyl 3: -3.1 to -3.5, cyl 4: .7 to .9, cyl 5: 2.2 to 2.3, cyl 6: -.5 to -.7, cyl 7: 1.0 to 1.8, cyl 8: .6 to 1.0. These are at idle, in park, 8mm3 delivery, but may not have been over 185F ECT. MAF reads within spec at idle.
I have before and after pics and videos of scan data if anyone is interested, minus blowing white smoke.
I have been directed to check the turbo, high and low pressure ducting, verify functionality of the boost pressure sensor, and check the MAF sensor. I have bought and hope to use some BMW injector cleaner that was more or less verified to be the same and the old GM/Techron cleaner on a different forum.
I am going to stop driving because of the knock, but I hope to do better diagnostics and a cleaning this weekend.... if my toddler lets me.
I am sure the shortest of the short answers is junk injectors, but I am worried that transition white smoke could be a deeper problem.
Does anyone have any thoughts?
Thank you
Long story:
Thank you
