Junkyard Diesel
Badaxe
Denver
When our trucks are out on the road they stand out a little bit. The tell tell signs of the 6.5 on the hood, the vented front bumper, the slightly larger exhaust, and the rattle and humm of the V8 diesel. On the occasion one ends up in the junk yard the engine, hood, and bumpers are usually the first parts to go. Is there a VIN # I need to watch for or some other distinguishing signs?
Beware of a diesel with the engine still in it at the yard! Engine failure is why it is there...
7th digit of the vin should be a f or s if it is/was diesel
I'm after the APP, which I hear is diesel specific.
Yep diesel only. I have an extra one $95 shipped in USA
Also diesels should have fuel caps that say "diesel" on them and the sticker on the fuel door says "Diesel fuel only"
I like the cables. I don't really understand the need or want for throttle by wire
Yeah but it's nice when you want to put cruise control in a truck that doesn't have it and all you have to do is add a switch or change the TS stalk and put the fuse in. Try that with a throttle cable. DBW is ok as long as it's not a Toyota.....):h
