Danish Farmer
Hi gyes
Finally giving up on my 1995 Silverado 1500 Z 71 6.5. I think of getting a replacement thats a little younger and most important, more reliably.
Too many electronic faults on the Chevy, too short life time for new parts, too hard to cure the fish biting, and just too many technical areas getting closer to an update or overhaul. Engine blow by, slack in the drive train, slip when kicking in the torcue lock, ongoing EGR-codes, ABS rotors are not living more than a half year, A/C system leaks several places, horribly milage (15 mpg) not towing, and just burned the turn signal switch and viper engine.
Seems like every time one problem is solved, another one occurs. A new light on the dash pops up, a new fuse blows or a new area starts dripping oil.
Have had it for two years, only put on 5000 miles but worked on it a lot. I just never reach the line where it seems like my threatment starts to make her more reliably and fresh.
Ran into a 2000 Ford F250 7.3 Powerstroke Super Duty Lariat at a local dealer with 150.000 miles on it.
Before closer examination, can I expect that truck-model to be more reliably if its well taken care off, and runs good at the time of testing it ?
Just want to have the feeling of getting back home with out a doubt when I take my truck for a long run, which is not the case in the Silverado. Sadly since I put in a lot of money for parts and apparence, chrome and lights
Best regards
The Danish Farmer
Best regards
The Danish Farmer
