rtdhsp
The second day of owning my 6.5td I pinned the tps at 20km till 50km let off and the tps stuck open for 3 secs then surged about 10 times before it died.
the pmd smelled burnt looked burnt.noticed the FUEL SOL fuse was burnt,replaced it and it burnt right away.
plugged in the old pmd no fire but didnt blow the fuse .
pluged in a pmd from buddys truck ,no fire
getting fuel to the bottom of IP but none out the injectors.
Im thinking the pmd took something else with it when it left us?
CODES read 13,22,25,63
13= fuel shut off sol
22,25,63=tps volts hi and low etc.
removed fuel sol,works fine in my hand.
it fired with diesel poured into the intake.
cleared the codes ,removed neg cables 4 times.
did the pdm blow the optic eye? or another sol on the IP?
changed the fuel pump relay also.
