vdb11
Halfmoon Detroit #2
alright thank you! I will be following with great interest!
x2 on the block heaters.... we live in northern quebec and we need the heaters.... that is factored into it as well... we have done some home work on this since last year, the main reason we dont want to fill it to the top is also the oil is cooled by transfer of the water in the jackets..... by the way i apoligize to the OP for high-jacking his thread..... but in a way this is good for him as well, seeing he had mentioned hard-blok a couple pages ago...lolI understand where your coming from but after a chat with Bill a year or so ago he told me all the blocks he builds get the tall fill racing or not. My issue with the tall fill is no block heaters. He feels that most of the heat generated by the idi engines is in the heads.
What needs to be machined after the filler is set up? You said that machining after helps to eliminate stress induced by the curing filler, which I understand, but what type of machining is required? Does it just need shined up or rounded or??
