How did you mount up you OEM sensors for boost and IAT that were on the original upper intake?i just installed my ATT tonight. i ended up using some couplings and pipe from my intercooler(which i removed) so i could retain the Peninsular upper intake instead of the stock upper.
Sounds like I should be planning on an intercooler. Oklahoma summer heat and possibly 30K behind the truck might be a bit much! I guess an ATT just won't heat up as bad as a GMx though.
HX 35 is goin on this weekend (hard to deny a $100 turbo), or atleast thats the plan if I can find a return line and the right supply fittings for the holset.
i drilled and tapped 3 holes. used a barbed fitting and hose for the MAP.
View attachment 25600View attachment 25601View attachment 25602
You will need an intercooler with the Hx 35, theses are things that nobody discusses about the HX35. There are no specs on drive pressures IAT Intake Air Temps, not to mention that you are running a turbo that is made for a 5.9 liter motor, and that boost starts lower on the rpm scale which is not good for our motors (18:1) maybe. The Cummings makes peak tourque at 1760 rpm, quite different from our motor.
I am not knocking the HX35 just that everyone says how good a turbo it is for the 6.5. well there just isn't any solid factual numbers out there to support how good it really is. And in Oklahoma how big a hills do you get? Guy down in Louisiana hauling 30000 LB trailer loads plus, without truck figured in and has not had any problems, so like I said maybe an intercooler towing through the west coast mountains when towing real heavy. I like my truck and a motor that lives a long time doing what it is supposed to do, haul my rear end anywhere I want to go reliably. Had my share of time on the side of the road alone.:svengo:
Turbine Doc- did you run the ATT with the intercooler or are you saying that you removed the intercooler when you installed the ATT?
