coxpn2
coxpn2
It appears my headgasket project was successful, as I've got some miles on the truck and she seems to run good and not use coolant.
However, I've got a slight tick/knock at idle, which I'm suspecting is an injector. It doesn't sound like a ticking injector line, just a slight interruption in the smooth growl/purr of the motor. I wish I could describe it, but its something like a tick/knock/miss/hiccup. Hopefully that narrows it down!! ha, that info is probably useless.
The injectors that are in it are from the engine I had laying around from the suburban. The PO said he bought all new parts 15k ago and built the engine, so I assumed they were injectors that were new with 15k on them. However, he also put a used crank in, so I suppose his definition of "new" could be rebuilt. They are Bosch, and I believe they have Germany on them also. I figured they were in better shape than the ones with 165k on them in the engine I did the headgasket on, so I put them in.
My question is; how can I know anything about the condition of the injectors? It seems to run good... I know you can get them tested, but pulling them out and sending them somewhere isn't really an option. I also know you can 'crack' a line to try and narrow down which one is the offending injector.
I am in desperate need of glow plugs/glow plug work/etc, as she starts really hard when it's cold. So I figure it would be the perfect time to try and narrow down what is making this noise.
I might be getting a little too particular doing this, but little things bother me. Personally, I love the sound of a smooth running 6.5, and the little tick COMPLETELY ruins it. Maybe it is something, maybe it's not.
Any thoughts?
Any thoughts?
