Its a little more like doing spark plugs.
The push on installation kit? Ehh the fender again that's a pita lol so is taking my down pipe off.
Lol I think the installation kit I'm getting only had two crimps so I'm guessing it's push on and the turbo gasket from a 88 ford thunder coup should work as I recall seeing before.The push on installation kit is for the injector return lines. Don't beat yourself up trying to install the oem style with crimps. You already have to do two injectors this way with the push on kit and that's bad enough. Ask me how I know.![]()
If I put the cap and crimp on how would I get the socket on it with the line of anf what about using a compression clamp.You got the right kit. The two crimps are for injectors 7 & 8. Paul and I found it easier to put the cap and crimp on the injector before installing it in the block, or rather I found it easier Paul has I'm sure done this enough to know better. I was the rookie on the job.
None of my friends have diesels and my gfs truck is a 7.3 and so is her dad's but 7.3 injectors are a cake walk there's room in the bay. What size socket is it.Before I picked up the injector socket I would use a 12 point socket or crows foot. These will allow for the replacement of 7 & 8 with the capped return nipple too. Just rotate the clip so the ends are against the injector.
The real problem with having an injector socket is once you have one, and your done with your own work, you're still tempted to use it and so you invite friends over....![]()
I'll probably get the injector socket or a crows foot because if I break it um going to freak.CAUTION it's easy to break the return nipples off. Keep the socket on there straight
Is that derived from personal experience?CAUTION it's easy to break the return nipples off. Keep the socket on there straight
Bosch usually builds the best of everything when they step in the game. That's who wins here also. Go to a Mercedes dealership, spend $13 and get the push on line that never leaks and lasts 150,000 miles.
