Jorge6.5
Its odd cause i needed a transfer case control module and also with that it could only be from a 96. What the hell
I to have a 96 and a set of 96 factory service manuals. Willing to look up stuff to help clear this up.Its odd cause i needed a transfer case control module and also with that it could only be from a 96. What the hell
I'll say you're welcome for all. :hihi:My transfercase is push button, and the thing about the 96 model year is what i was told by a mechanic and salvage yard.
Im getting tempted to do a manual swap. Waiting on phone calls tomorrow to find out about some 4l80Es
Thanks a lot for all of this info
Yes...replace it, the lockup clutch wears out and you might have a locked up stator sprag. It is an unusual situation these days where you would not replace the convertor with at least a rebuilt one, when rebuilding the trans because its worn out, due to the TCC being inside the convertor (its not in a few trans). Say if you broke the sun shell / shaft joint then you might not replace the converter on a low mileage trans.Any concerns I should have about the torque converter? could that be toasted or should I have it inspected?
