Shop manual lists lobe lift @ 7.133 mm + or - 0.05 . That's .281 inches lobe lift multiplied by 1.5 rocker ratio = .421 . This would be easy to check , just mic the lobe and the base circle . That I can do on a stock cam .
The base circle is the " round part " and the majority of the lobe . The " ramps " are the parts leading to and away from the peak or tip which is of course max lift . Measure the base circle from 9 - 3 o'clock , with the lobe straight up at 12 o'clock , and that will be the base circle dimension . This is the diameter of a circle if the lobe was not there . Since this goes around the cam for at least 180 degrees , with the lobe at 12 o'clock , you can now measure from the bottom , 6 o'clock , to the 12 o'clock position . This dimension has the base circle dimension subtracted from it resulting in lobe lift . Think of it this way , put the lobe @ 12 , measure from 12-6 and 9-3 and subtract .
I just noticed today that my tach has a peg at 5000 rpms,but it kept revving higher,would guess around 5300 rpms. I would go solid lifters,before variable duration hydraulic. Or hydraulic with .002 lash.
| ground in advance 7 degrees | |||||||||||||
