How many aftermarket gauges are in your truck.
  • None Factory set up works for me.
    Votes: 6 28.6%
  • One
    Votes: 2 9.5%
  • Two
    Votes: 3 14.3%
  • Three
    Votes: 5 23.8%
  • Four
    Votes: 3 14.3%
  • Five
    Votes: 0 0.0%
  • More (please tell us more)
    Votes: 2 9.5%
  • Total voters
    21
No money for the gauges as of yet, maybe one day! :thumbsup:
Factory gauges works for me. :agreed:
you gonna be glued to those 2 with those new tunes you just got.;) once you get a taste for how it'll pull when rollin into it, it'll be hard to keep out of it.... trust me:sifone:
7.. yes 7...
Matt, show off....:hihi: Now go vote.....
Let me guess..
1. EGT passenger side
2. EGT drivers side
3. Boost
4. Transmission temperature
5. Differential temperature
6. Rail pressure
7. Water temperature...:dunno:
Let me guess..
2. EGT drivers side
3. Boost
6. Rail pressure
close, pretty good memory you there too.....:cheers2:
1, 2, an 3 yes.... on drivers pillar.
4 gauge pod over rear view mirror at the headliner.....
1. Hot side engine oil temp
2. aux fuel tank in bed level
3. air pressure 0-150 for bags
4. air pressure 0-150 for air tanks
all gauges are Auto Meter Phantom Series, White faces, Black numbers, Red needles.:D
and yes there is a difference in EGT from right to left..and thats another story for another time:sifone:
One Glowshift fuel pressure but I want a tranny temp and I want to know my exhaust temp I think? Also I want a vacuum pressure gauge on my air filter.
Right now:
Boost (with blue remote warning led at 12 psi)
Egt (with red remote warning led at 1050)
Water level (just a blue led though)
Water injection rate (flashing led to indicate rate, steady at full on)
Yet to come:
Oil temp
Trans temp
Rear diff temp
Fuel press
Coolant temp
Here's the idea:
The two in the "cubby panel" are really there. The ones in the lower console are photoshopped.
Here's the warning LEDs:
LEDs are really there, labels are photoshopped.
Not sure how to vote in poll, I guess it's only two ifyou strickly define it as " gauges"....
Currently 4 gauges, Boost-EGT-trans T-fuel P, 4 LEDs for lift pumps power & fuel filter DP switches. MT2500 for everything else on engine but some of those featueres at some point to be monitored via gauge/meter or A/D conversion panel meter similar to BJs setup at some point down road if I ever get time to work it. Must be a turbine thing eh BJ to monitor engine parameters. ;)
