nycxjeremyy
Its mainly left right sirI can't tell from your video, but can you feel any play left-right / up-down or push-pull? there should be no play in that regard but a little rotation play is fine.
Copy sir, thank you
I checked the u joint on the transfer case side sir and it moved smoothly, the rear/diff side one was the one that from the get go i felt resistance in.U-Joint, as @Will L. said, look back at My posts.
Drip that drive shaft, check them U Joints and confirm that there is not a dry trunion.
Takes about a half an hour, one wrench and a smalish pry bar, or, large screw drive to dislodge the joints from the yokes, not more than ten skinned knuckles and a dozen words from the mechanical vocabulary list, only then can you be reassured that it is, or is not the you joints, and, it will beat down my curiosity too.![]()
I did that the yoke trick sir, still was a bit tight, but i had no issues rolling without giving throttle when in D or N.when installing new u-joints if they feel stiff there is a trick to relieve the stress on them. you carefully whack the inside of the ear that holds the u-joint on the driveshaft to slightly spread them apart. one or two whacks usually will do the trick, just don't whack the joint it's self. there's lots of youtube videos showing this.
Did You center the joint within the drive shaft end ?I checked the u joint on the transfer case side sir and it moved smoothly, the rear/diff side one was the one that from the get go i felt resistance in.
When i added the new u joint it did feel stiff though
