D2 Cat
It's wet, cold weather here and the truck is setting in it!!
Can someone give me an idea of the length of hose required to replace from the fuel monitor going to the steel line going to the LP?
Does this line just go down over the bell housing and clamp to the steel? If I had it on a lift it sure would be easier to see!
I've been trying to isolate fuel leaks. I accidentally left the LP running about 3 hrs. last night. This morning it looks like a "tear drop" from the width of the front tires to three feet in front of the truck some fuel has leaked from somewhere.
Everything from the fuel monitor to the IP and the WIF drain is new. Seals at FM checked and OK. Returned lines replaced on Driver side. Has to be either the return lines on the pass side or something before the FM.
Any ideas? Anyone know the length of the 3/8" hose? Thanks.
