Ok well I spent all day working on this truck, put pads on the front and had to pull the passenger caliper off and use a little elbow grease and a very big hammer but was able to get the frozen piston to release. Working great and free now remarkably as I figured it was junk. But it came out good, bled the front and still didn't have a pedal, was throwing the brake light in the dash on, was scared it needed a master as my dads 99 suburban had the exact same problem (hanging caliper) and we also had to put a new master on to eliminate the problem. But I decided to bleed the rears to see if air made its way back there and stumbled upon a pin hole in my brake line leading to the split in front on the rear end, well having to drop the half full tank to get to the fitting because it was a napa line so I do not know if factory fitting for the 3ft line was right beside the tank, dropped the tank replaced the line bled the rear and rebled the front hours later she is stopping as good as new. Whewww...now that that problem is taken care of I know the hanging caliper was not the whole reason for bad mpg, so tranny? Full of fluid but i have not pulled the pan off and gotten into it. I will when I have a free chance.
