I recently cleaned the radiator and the other coolers - it makes a huge difference. I did use a combination of Castrol Super Clean and Simple Green. I used a pump-up sprayer with a spray wand attachment. It worked very well. I was able to go over every square inch of the radiator, spraying into every opening.
I admit I did NOT actually completely remove the radiator. I removed the electric fans, and undid the top radiator mounts, and pivoted the radiator away from the frame. Also, I loosened the AC condenser and the oil and tranny coolers, and moved them away from one another. I also used a garden hose sprayer with a very small head to actually get in-between the various "heat exchangers", and probably did 3-4 "Spray/Soak/Jet Rinse" cycles. A LOT of bugs, dirt, leaves came out, and by the time I was done (like 4-5 hours later), they were just pristine. I wanted to avoid taking everything apart, and I think I succeeded in getting the radiator pretty darn clean.
I also put fiberglass screen-door mesh in back of both my grills to block bugs from clogging the works in the future.
It has made a HUGE difference in running temps. I have an HO water pump sitting in my cabinet ready to install, just haven't gotten to it. However, the radiator cleaning on the Tahoe has dramatically reduced the overheating tendencies I had before. It was 90 degrees the other day, and I went up a 14 percent grade for like a mile, and it did not go over around 205 degrees. Before, I would have to pull off 1/2 way up and let it cool before continuing.
Good luck!
-Rob
