Big T
Looks like an Optimizer. Claims only 1200 miles. Nearby me in Anaheim Hills.
Look at this post on Facebook https://www.facebook.com/marketplace/item/364468672912199/?mibextid=HHaHfI
Buy them. Ship them to Montana, I’ll title them for You. Have to have the vehicle here though, LEO has to do a SN inspection on the tag, or frame, then rdcord that on the paper work.Commonly the go water fording and don’t dc the fan hub. Fan shatters from trying to become a propeller under water.
Mileage is very believable- tons of low miles Hmmwvs being sold without any miles to speak of for around $10g. People do a LS, cummins or dmax swap.
If they were legal to title in this state - I would be buying from auction, make shiny and sell for descent profit.
Adapting in the truck intake would be a pain from bolt angle. I did the reverse on mine using that intake and turbo onto mine that basically has a truck intake minus the ffm mounts.
That db2 could be altered into 12v for about $200.
You could remove the turbo and block of the oil ports. Sell it and the exhaust manifolds with up pipes. Then buy the adapter piece for coming from the inner cooler from ModMafia and make your own hose adapter.
Do you have a link to the fuel pressure T?Just looked up that mod Mafia part- $720 - for that price I might have something built local first.
Myself- I could fabric something. So depends on the person’s skills…
modmafia.com
modmafia.com
Here is the fuel T fitting from ModMafia.com
Fuel Pressure Gauge Adapter
A fuel pressure gauge is essential to monitoring the health of your fuel delivery system. Mod Mafia makes it easy to add this important gauge to your Hummer / H1…modmafia.com
The fitting goes in between your incoming hose and the ip.
You screw the fuel pressure sending unit into the 1/8” port on the side. Only thing you have to add is the fuel pressure sending unit. With it screwed in nothing can leak, you could drive truck and do the gauge part later if needed.
I posted pics of one installed on a hummer intake- that is really tight but fits. The truck intake has a little more room there.
Do you have a link to the Summit part?Dang, a 50% mark up vs summit.![]()
Not right off, I just bought a few myself for tranny temp and other gauge places so I know they are much less and readily available.Do you have a link to the Summit part?
You have to know the description of what you're searching for.Of course I see nothing wrong with that mark up, if folks can't search for stuff themselves and find it at a lower cost then by all means charge them for it..
