jamierayo
Enter Witty Title Here:_____
I've been thinking of wiring a high idle switch through a thermal switch made for an electric fan. That way, when I flip the switch on, it would remain at normal idle until the temp dropped to the set point (I'm thinking 160* F), then it would automatically throttle up (I'm thinking 1360 RPM), and then drop back to idle when the temperature rises.
Here's the problem: I need to connect the ECM B7 wire to ground to enable the high idle. All the thermal switches I've found are normally open, and when the temp rises, the circuit is closed. I need it to do the opposite & complete the circuit when the temp drops below the set point.
Any electrical gurus know how I could make this work?
If you are wondering why, it's because I sometimes need to leave my truck idling for a while, and at temps below perhaps -25*F, and at normal idle, after 5 minutes of idling (cooling off), the engine is so cold that the needle on the temp gauge is bottomed out, and the heater blows cold air. -Yes I have a cold front over the grill & cardboard in front of the radiator.
