Chevypoor
Active Member
I am 100% clueless on the HVAC set up on these trucks. The truck in question is Gertie, a 1995 GMC with factory air. The AC does not work. However even on the vent setting on cool mornings (in the upper 50's) she will blow hot air. Have been in other 95s with non working AC and the air from the vent mostly reflected the outside air. When I turn the key to let the glows light I can hear a whirring noise from under the dash in the vicinity of the glove box door. I can also hear the blend door (or a "door") pop open. Any thoughts/ places to start?
