12ga diesel
Jack of all, Master of none
Just got done changing the OEM fuel filter, followed all the steps, to take it off and install the new one including to loosen up the bleeder screw and prime it. Closed the screw once I saw there was fuel coming out of it, and then primed it a few times more until the primer felt stiffer when pushing down on it. Truck started up right away with the fuel left in the rail, but then died after about 45 seconds running. Primed it a couple more times, got it to fire up one more time, for about 30 seconds, but again died. I have tried a couple more times, but no luck. I will let it try to turn over for about 5-6 seconds, but nothing. Is there something I am missing or not doing? Was pretty easy to change out the fuel filter but this seems to be the only snag I have ran across. Thanks for any help.
