valyidol
Active Member
Das anybody remember where can I find the post about optical sensor?
Time for a new OPS and then do the relay mod
Sent from my Studio 5.0s using Tapatalk
Thanks. I know about intake. My question is about how to cheat the lamp CHECKIf you have the parts available it is best to change the upper and lower intake to F intakes. That will remove the EGR.
There is more to it after that. I will be doing the 95 Tahoe soon. So I need to read up myself
You can use button My RepliesThe answer is probably here. I am terrible about searching and finding what I'm looking for. I can't even find posts I've made.
Thanks. I'll think about it for my truck. But now I'm doing my friend's truck repairMy opinion only: loose the ds4 injection pump for a db2. If you have an automatic transmission buy a trans controller from Leroy, if manual trans-no worries. Read about ds4 - db2 conversion by Bobby Martin. This eliminates any need for pcm and the ever troublesome pmd. All US Military vehicles that use a 6.2/6.5 platform use db pumps only. Thats because they are more reliable. The amount of performance gain available from ds4 is so little it is not worth it. Especially with your remote access to parts and supplies for this engine.
I want to remove EPR valve. How can I do it, not to the light "check"?
And what is relay mod?
