chi2
The article on Bill Heath's/Heath Diesel's Bonneville truck was a fun read and the truck looks great. I will be rooting for Bill and his team to exceed 130 mph for a record:thumbsup:!
I was left confused about the logic behind some of the engine build features, and hopefully the knowledgeable folks here can help me understand.
The article stresses that Heath's truck had to include a stock 6.5L TD: "The 6.5L engine must be in stock original configuration (stock block, crank, rods, pistons, heads, cam, etc." (p. 24; maxxTorque, Summer 2008), but the actual build seems to deviate quite a bit from a stock configuration. For example, the crank is replaced with a SCAT 9000 series crank, the pistons are replaced with Mahles, which have a special ceramic coating, custom headers, two turbos and some hydraulic concrete coating for the cylinders and crankcase (to name a few
16
. In addition to the core engine features, there are many additional modifications, a la the HDP products (TM, FASS, water injection, HO injectors, cold air intake and more).
Perhaps I do not understand the rules for the Bonneville race? Do racers need to have (nearly) stock engines for the "B" class diesels? Does their engine classify as nearly stock?
Did Bill and his team want the truck to be a model for others looking to upgrade with Heath products, and therefore wanted to keep the engine build within reasonable reach for the "ordinary" folks?
The biggest question for me is about engine compression: Why didn't Heath use 18:1 compression? Many of the knowledgeable engine builders on this (and the old) website move to an 18:1 compression ratio, but this is suspiciously missing from the Heath truck.
Jon
Jon
