When you start by saying I believe he is doing more help than harm and I harbor no ill feelings against him for his efforts. It has been years since I went through his site, so I glanced at only ONE thing from reading you post till now responding incase he eliminated some of his errors. I found a couple that have been there for about a decade.
His rear head cooling kit. This design has long since been proven to cause issues and does not solve the problem. That is why Bill Heath (iirc inventor of the original kit) quit selling it and speaks out against it every since he learned of the draw backs. I gave Chuck Kelson (owner of flashoffroad) all the info including test documents of GM from their testing this process and looking at in multiple locations including a complete secondary radiator. I also gave them the documentation showing where the US DOD got the original engineering Study showing that GM knew of the unbalanced waterflow problem. That is when the DOD forced GM to manufacture the 2000 model water pump retrofittable to all Humvees, and pickups. Flash off road makes a profit from selling multiples of the kits, and that I believe is why he will not acknowledge the balanced waterflow repair and quit selling the problem causing rearhead flow modification.
Carefully re read the pages about anti freeze.
"This doesn't mean that your engine is not affected by cavitation only that it hasn't been a problem in this particular engine." I sent him GM findings, as well as USFLEET findings showing the opposite and all the Dexcool info, since we had just won the lawsuit only a year prior. Read through his material on cylinder liner cavitation, then learn about things like regular cavitation from excessive heat, (search TTS waterless coolant less for the quick version), then you can look at Detroit's research on the effects of electrolysis in cooling systems. While his information in that part will not cause you to destroy your engine, it is misleading that only wet sleeved diesel engines suffer from this.
There was a lot of info I sent him he chose not to mention on his site, which is fine. But it upsets me on someone making money on items that is well proven to do damage to the most expensive part of a rig, the block and heads of the engine.
I know some of the people here get tired of me banging the drum on the GM coolant issue, and say it has been fixed now, after the third version. The fleet I used to run with over 100 pick up trucks alone sued and one on the first version, second version, and settled out of court on the third and current version of their coolant. That company, Which I no longer work for, now gets complete new engine and radiator replacement for all their GM fleets vehicles free of charge from any GM dealer at 75,000 mile intervals. They are still running over 30 pick ups two above the 300,000 Mark, and sell them with the FIFTH engine & radiator combo having been installed all for free, at corporate's expense. But yeah, I'm sure they fixed it THIS time.
