- Staff
- #1
I want some input on this before I purchase anything.
Both items I want can be purchased from LMC.
The first is the headlight harness. All this does is take all the electrical load off the headlight switch. Which on my model truck is to much for the switch. When I replaced my headlight switch over two years ago it was a little black on the white connector around the area were it gets the power for the switch. It seems all this kit from LMC does is add relays and makes it a plug and play. Easy for someone that does not want to make his own.
The second thing is a all headlights on when you turn the high beams on. I have no clue why GM did this to begin with. I have had this in the past and sometimes wish my truck had this. Once again this is plug and play. Also this makes it easy for someone that does not want to make anything.
Thanks for the input! :thumbsup:
