Just leaks enough to be annoying! Always around the starter and passenger side of the tranny dust cover. I have done the following....Replaced all the return lines on that side with the good stuff, new filter manager, tighten all the fuel lines, return lines to and from ip behind filter no fluid what so ever in the engine valley... only has 25k on the injectors and I checked them as well when I did the return lines. Any hidden lines? Any ideas? Does it look like oil or diesel? Posssible that the fuel lines that run behind the engine are leaking? I can't find it!:mad2: Yes I have a tranny leak but its not that fluid (bad seal where the gear shaft goes in)
