GMT-400 to GMT-800 brake conversion tie rod discussion
I don't know if it makes a difference but the one from Speedway is a 2" PER FT 10* and the one from Wallmart is 1.5" per ft 10* I have the one from Speedway but was getting ready to order one from Wallmart, not sure if there is that much difference. From the holes I've reamed it may be better to use a more dull reamer so it actually goes straighter and more forgiving since it takes less metal per revolution. I've had to do them all by hand or with a drill since machine shops that can actually do them want alot of $ and bitch about how hard it is to mock it up straight in a CNC machine. Atleast in my neiborhood of machine shops. I have practiced on some stock boneyard GMT 800 knuckles since I have to do a set of Rancho 4" lift knuckles for GMT 800 truck that cost me $750.00 to fit my GMT 400 with a 4" Trailmaster lift.
The intro paragraph for WalMart listing says 1.5” per ft 10 degree, then down below in the description it says:
Item details​
  • with high thermal hardness, high wear resistance, high hardenability and sufficient plasticity and toughness. and can withstand large impact force and high load operation, can be used many times
  • 10 degree tapered reamer is a universal tool,Tapered Reamer Tie Rod For 2inch Per Foot,tapered designed for proper fitting of ball joints to spindles, tie rod ends to spindles,tapered holes to hold tie rod ends
  • Tapered reamer, 2inch per foot taper (10 degree)
The picture looks the same as the ream from Speedway.
I’m doing them by hand with a right angle drill. Getting the depth right is the tedious part.
I’ve got the tie rod holes reamed. Will be working on the depth for the ball joint holes.
Item details​
I'm not getting the difference between the reamers.
Like Marty, I would thing a 10° reamer would be a 10 degree reamer.
Is the 1.5" per foot part of the description, just a mistake?
I thinks it’s 2” per ft gets you 10 degree, while 1.5” per ft gets you 7 degree.
I still cant understand why it would be labeled a 10* reamer if it is actually a 7* reamer. 🤷😹
I just dont get it. 10* should be 10* no matter the distance.
A mountain grade sign says the highway is at a 7% grade, it dont say 7% in 250 feets, its 7% the entire length except a short stretch at various places.
The error is in the first line description. Down in the details below they have the specs right. They are the same.
Received the ream ordered from Walmart at our Montana home and my wife sent me a pic asking if I wanted her to bring it down to SoCal. The packaging is the same as for the ream I bought from Speedway at 4x the price.
Heres some pics of my Rancho lift knuckles with the ball joints done. The knuckle is bolted upsidedown in preperation to ream the steering tierod ear but I rotated the pics 180 degrees so they look upright. Not sure if I'm going to be able to use the tie rod end in the photo or I may have to use heim joints sincs Rancho raised the tie rod ear 2 inches which makes a clearance issure with the differential on the drivers side.
Oh well this wonderfull I phone 16 takes too big of file pictures to download here, I'd like to through it in the lake behind my house!
Resend the photos to your e-mail and download those. They should have a smaller size after one send and then can be uploaded.
If on iphone.
Go to photos, tap the photo You want to display.
At the bottom, tap the three lines with the o on them.
Choose the CROP option.
Then move the black border and corner markers to eliminate any unecessary portions of the image.
If the image needs to be rotated then at the top, left side, the square with the circular arrow, tap that, it will flip the image around, several times until its headed in the right direction.
After its shrunk or rotated to Your satisfaction then tap the done at the top right.
