Will L.
Did you relocate the pmd? Possibly bad extension cable.
yes ip injection pump
App is the throttle pedal.
Has anybody used Pensacola Diesel for their pumps and parts??
So, you changed a working PMD WHY?Hey Guys I need HELP! Gosh my truck has been running pretty good, Thursday it started doing strange things. At idle it runs good but when I add a little throttle it goes to a high rev like I have it to the floor but I only have a light touch just laying my foot on the pedal. Going down the road I had to feather the throttle to keep going at a safe speed. it's blowing some black smoke and seems like it's starving for fuel (full tank) and all this just out of the blue. I am a pretty good mechanic but I am stumped!!?? Can anyone shed light on this?? Most of my past experience has been with Ford's 7.3 and 6.0. I thought maybe the injector pump might be the issue. Any help would be great-this is my daily driver and rainy season coming to Florida soon. Thanks for the help. Oh I changed the lift pump, fuel filter and PMD.
Wayne
WOW thanks for all the info, well from reading other forums and asking questions I went with the simple stuff first to try to isolate the issue...New PMD and cable, New lift pump-yes they both work, I also installed the lift pump harness from Leroy diesel which puts a full 12V to the system. So the pedal must have a clock spring like the fords do...I'll check on that. My lift pump and PMD came from New York and I have been looking for more AC Delco items. Do you know of a rebuild kit for my IP? Otherwise I will have to locate a better source for a IP either rebuilt or new. I think the manual IP's had a FIPL sensor on the side. Thanks again and I will be looking for more help.So, you changed a working PMD WHY?
OH also the PMD was relocated when I bought the truck, but I installed new cable and relocated to a cooler spot as well.WOW thanks for all the info, well from reading other forums and asking questions I went with the simple stuff first to try to isolate the issue...New PMD and cable, New lift pump-yes they both work, I also installed the lift pump harness from Leroy diesel which puts a full 12V to the system. So the pedal must have a clock spring like the fords do...I'll check on that. My lift pump and PMD came from New York and I have been looking for more AC Delco items. Do you know of a rebuild kit for my IP? Otherwise I will have to locate a better source for a IP either rebuilt or new. I think the manual IP's had a FIPL sensor on the side. Thanks again and I will be looking for more help.
Awesome info and many thanks....I will try to put my info on here, got to try to navigate around the site. I have been in contact with Leroy and have a couple parts from him, I have an A/C harmonic balancer as well. I will try the things you mention and hope I can pinpoint my issue. I sent a mag to Leroy as well and waiting for a response. Thanks again.If you have access to a scanner, pull codes, maybe something helpful there?
Agree that it sounds like IP is going bad, sorry for your luck
Also check intake/ turbo. I once had a K&N filter collapse under the hood and plug the turbo on my first 6.5, a '99. Truck had no power and was belching black smoke, acting like it was starving for fuel. Air filter had collapsed and was plugging the compressor wheel so it was starving for air. Even if the truck is relatively low miles the GM turbo is most likely spanked and not worth keeping in my opinion. I've been happy with @uniquediesel's towing turbo to hold me over until my CAC and HX35/40 install
And yes STAY AWAY FROM PENSACOLA DIESEL. If staying with DS4 go with Leroy or Quadstar. If you want to eliminate electronic injection issues forever now would be the time to swap to mechanical DB2
Thank you, I will doing alot of work this weekend to try to isolate my issue, was told by Southeast power equipment here in Tampa (they are a Stanadyne authorized dealer) that Stanadyne no longer makes these pumps and parts are scarce. If I need a pump they have one reman that fits my truck...so the search continues.Clean the ground wire terminals at the back of the right side of the engine. Should be three wires connected to a stud back there.
Thanks, yeah I have emailed Leroy several times and gotten a couple things from him, I sent him a msg about as well and haven't heard back from him. I don't know about Quadstar but Leroy's price is above my means right now.The shop is lying to you about availability of new DS4 injection pumps, see here
Reman from another site vendor
Remanufactured DS4 Injection Pump with PMD
GM DS 6.5L Fuel Injection Pump These pumps go through a thorough re-manufacturing process and get reassembled to OE specifications. Components are completely cleaned, inspected, and tested. Worn or damaged components are replaced with new to ensure maximum quality and longevity. All of our...quadstartuning.com
When you say you installed a new throttle pedal, do you mean a new APP sensor (Accelerator Pedal Position)?
If the truck is surging as you say and all other components have been replaced from crank position sensor to PMD, then it must be the IP. Pull codes with a scantool before going full nuclear and putting in a new IP. I'm no expert in this realm but based on what you've done I don't know what else in the system could be the issue outside of IP
