turbopower6
Hi all,
I just replaced all of the glow plugs using Bosch Duraterms (with anti seize) and put in new injectors from Bill Heath while I was in there.
Last winter It was difficult to start unless it was plugged in for a few hours. Without plugging in it would not start. New batteries did not make the difference. When it was running and warmed up it would fire right over as it should. Let it get cold.....well let's say it was always a pucker moment if it would get you home.
The Question: the AC Delco glows I removed were not swollen (thankfully) came out like spark plugs (easy) and looked to have intact tips at the business end. Sooo---oo how would I know upon a visual inspection if these were the problem? Seem to look fine from my view.
Some more insights: the wait to start light cycles as it should, I can hear the relay clicking does this mean the system itself is really working as designed?
I am finishing up the "adventure" now and will not have a really cold night to test it out so I am hoping next winter we are GTG!
I added the glow harness and 2-0 Battery cables from PT Wiring while I was up to my elbows in the beast and looking forward to not being back inside anytime soon!!
Thoughts?
Thank you!
Ted
Thoughts?
Thank you!
Ted
