D2 Cat
I notice the needle movement on the volt meter, when the turn signal is on the meter dips. Is this a typical symptom of mid 90's vehicles or is it caused by bad grounds?
Sounds like you've done War Wagon's 'Big 3' times 2. You've run a ground from each battery to the frame. Kinda redundant, but I like it. I'm gonna be doing a lot of preventive maintenance next weekend. Think I'll add this to the list.Mine just about stopped fluctuating when I added redundant engine/cab and engine/frame ground wires. At the same Time I added a Neg to Frame on each battery. (I used the bolt that holds the front brake flex line on basically directly under the battery in the wheelwell).
<clip>I'm gonna be doing a lot of preventive maintenance next weekend. Think I'll add this to the list.
The headlamp switch was a very common problem. They would heat up a lot. If yours gets warm on the outside after being on then I'd replace it with a new ACDelco, as the new ones are more robust to solve the issue. Mine would cause random no dash lights or no tail lights. Only swapped switch and it no longer gets hot and solved the problem.
Otherwise if you have some kind of aftermarket 3 to 2 converter for trailer lights cut it out and see if problem goes away.
