fuel to the ip but no pulse??
turninburnin
United States
hey guys new on here i have a 1995 6.2 diesel with a 6.5 injection pump and turbo all switched over so i should be running now right? wrong i have fuel to the pump but no injection pulse i have replaced my pmd with a new one from stanadyne but still no one home any help would be greatly appreciated:mad2::rof:
Is the pmd remote mounted? Because the extensions have been known to cause issues.
Can you update your signature to tell us what is the project, I'm a little confused was this a 6.2 engine swap into a truck that came with a 6.5 EFI IP/PCM/harness originally and you swapped over the 6.5 turbo parts onto the 6.2 engine ?
checked all fuses getting it on lift tomorrow it was originally a 6.5 but was replaced with a 6.2 with swapped manifolds intake and ip from the 6.5 its been a bitch of a project need to check grounds
