Looks like my tank leaking. Looks good where I can see it but behind the plastic there must be a hole or a rotten section.
If you want to pay shipping, I have two 128 liters (34 gallon) tanks out of 93's sitting in my backyard.
That's a mighty fine offer man. The world needs more guys like you. :thumbsup:
My truck is a short bed, 26 gallon tank.
Anyways it looks like it's the lines at the top of the tank and I am just going to replace them up to the pump as it is also leaking up at the motor as well. It's odd as the truck is not a rot box, frame and floors are still in great shape, just the lines are crappiy at all the connection points. I just did my rear brake lines for the same reason.
I want to convert to a rear mounted tank from a suburban and I may as well just do it now.
Matt, I am going to replace everything like you said. I don't want to do it twice.
Pay close attention to the details of your FSU when you install it. Note the sock, and the details of it. Compare it to the one you remove.
Something went wrong on my install and i'm showing out of fuel symptoms 11 gallons deep in a 22 gallon tank...
I have to do it twice
