WhtThndr3
Yeah, I'm that guy
Does anyone have any good ideas on how to get that stupidly placed fuel filter changed? :incazzato:
The way I do it is to partially drop down the passenger side fender liner. It is only a couple of screws and one of those plastic clips and depending on how big you are you should be able to reach it. Once you drop the fender liner you can reach in with both hands disconnect the WIF sensor and spin the filter off from there with very little spillage.
thanks. my only concern is how long is that liner going to last taking it off/on. I'm sure we take care of it better than paco in the service department. thoughts?
I loosen the filter (by hand) and disconnect the WTF sensor from above, then lift the corner of the fender liner over the upper control arm enough to get my hand in there, take off the filter and pull it out. Install the new one the same way and only tighten it down by hand. No pulling the clips out, no bending ac lines, no cussing, etc for me this way.
X2...In addition, I put a Zip-Lock bag around the filter, seal it shut when I unsrew it off the head, and let it drop onto the frame.
