Front Bump Stops Crushed - Normal?? - How much to turn up TBs.
dka99burb
Reidsville, NC
Still going thru my initial 'tune-up' with the purchase of the new-used truck. Shocks were crap. Rear bump stops look like they have never touched. Fronts are destroyed. Is this common? It does seem to point downhill but I thought that was normal for GM without being leveled.?. I plan to crank the torsion bars up. How much should I start with? I was thinking about 3 rounds = 1080 degrees of the bolt but I have never done it before.
Thoughts?
Bump stops on mine are like new. I cranked to have about 1/2" of downrake towards the front when new. Took 8-9 turns to get there. For starters get measurements, jack it up, crank 5 turns, drop it fast (to get it to settle), measure again and see where you are. Tweak from there and don't forget that corners are involved - ie: LF affects RR and RF affects LR. When you get where you want, take a short bouncy ride, re-check, tweak as needed and go directly to the alignment shop because it's gonna be way off and wander all over since the caster will be near neutral.
Don´t crank em up to much or the ride will be horrible. I tried to level my sub with the t/bars and the ride was so bad I retuned them to a couple of turns more than original.
Just saw my new wheels visiting my brother. They look great! He thinks he found me 2 BFG ATs in 285-70-17 load range D cheap. Now I need to find two more.
