chevytrucksonly
Dixie Ridge Runner
The firewall heat/sound insulation is falling apart under the hood. I have found three products, but need to know if anyone has used them and would like your candid opinion.
Product Features
1) Thermo-Tec 13575 12" X 24" Adhesive Backed Heat Barrier
Aluminized Heat Barrier is made up of woven silica with a flexible aluminized finish; the highly reflective surface of the material is capable of withstanding radiant temperatures in excess of 2000 degrees Fahrenheit
The adhesive backed composite construction material can easily be applied to any surface or wrapped around a hose or wire to make a clean professional appearance.
2) Thermo-Tec 14100 24" X 48" Cool-It Mat
The Cool-It Mat is composed of resin-bonded silica blanketing insulation sandwiched between a mylar facing on one side and a foil facing on the other
The highly-reflective mylar reflects heat away from surfaces while the foil side is orientated away from the heat source to conduct any penetrating heat across its surface thus providing the ultimate in heat protection
The silica blanketing is a duel-density composite and is the main sound insulator; it is easy to trim and can be applied with the push-in fasteners provided or any weather strip adhesive
3)CSI 25070 Heat Shield Insulation: 4 ft x 6 ft
Helps to eliminate heat, cold, moisture and noise
Consists of two sheets of pure industrial grade aluminum laminated to fiber tech padding
Great for floorboards, engine compartments, door panels, etc
Thanx
MDS
Product Features
Thanx
MDS
