Nessmuk
My setup is a 10 micron racor with the heater, water separator and sensor. I pump fuel into it, and then up to the glass filter, next pump and 2 micron filter.
I keep getting goopy white stuff in the clear filter. Is this bio stuff growing?
My tanks are set up to be on tank one whenever the selector valves have no power, and tank two when they do.
What sort of valve do you have? Some select the sender with the tank switch. Another way is double or triple throw switch, with one throw controlling what sender is being read.
I can draw up a diagram if I know what valve you have.
