john65td
Addicted to boost
i recently put a 6.5 non turbo from a 98 van into a 95 suburban. basicaly i use the short block from the van. the issue i'm having is the fan. the old one was not there when i got the motor. the water pump has ho stamped on it so i assumed its a high output. i ordered a fan and clutch for a 98 van and the clutch doesn't line up to the water pump and the fan doesn't fit the clutch.
the fan is one for a 98 also. the 95 fan clutch won't fit either, the holes are different. its got 4 studs its the bolt on type. any input? i would like to find the right fan and clutch to get this back on the road and so i can get paid. i'm about ready to change the water pump.
