F350 with a 6.6 Brazilian
thumper_65590
Missouri
Hello everyone, been registered for a while, but this is my first post. I have a 95 F350 Crew Cab that the PO swapped in a 6.6 Brazilian with a 545 Allison and a 7041 Spicer. Anyway, I have a few questions. 1st off, has anyone turned these up, and if so, how much? 2nd, would a 643 Allison be a better transmission? I have to redue the driveline and build some new crossmembers, so if the 643 would be better, now is the time. Let me know what you think and thanks, William.
JayTheCPA
Annapolis, MD
Welcome to TTS!
Interesting powertrain setup. Given the 6.6's power range, can see why the Spicer was added. PO might have pulled the entire powertrain from a dump truck and dropped it into the pickup. Am also a little surprised that there is not much information on the motor seeing as it apparently was in use for a while, durable, and in production until around 1990. Also, it looks like RockAuto (a site vendor) still stocks some parts for it.
Saw some chatter on PSA, so might want to start a thread over there.
