Brooklyn Tow
9 11 Never Forget
Anyone have any P/N's on any larger than stock oil filters?
Part number??????I know I've said this before, but run a DURAMAX oil filter on your 6.5's and call it good. It will fit a 4X4 no problem, costs the same as the 6.5 filter normally, and has almost a half quart more capacity. It is more than up to the filtering needed for a 6.5 as well as it is designed for the higher flowing DURAMAX engine.
So the 6.5 calls for a no bypass? i just searched for the duramax K&N oil filter ps-3003 and it says yes for bypass, No good on the 6.5?
And changing oil according to how much fuel is burned not necessarily how many miles driven.
