nobby
Old Timey Diesel Guy
So my truck last night whilst driving revved right up then stalled. Kind of alarming as she dropped down a gear and charged towards the car in front! Try to start it and it revs up then stalls. I found one other case on this where the PMD was changed with no result which was prophesised to be a bad IP, broken Fuel solenoid armature there was no feedback result.
Called my pump rebuild shop described my symptoms and his response immediately and rather emphatically was bad IP due to the FS armature and not to waste my time changing out PMD's or troubleshooting etc.
Lift Pump checks out OK,
Do have a code P1216 which is Fuel Solenoid response time to short, the only relevant check in the diagnostic is to check the closure ground circuit for and open, this goes between the PCM and the PMD wiring visually looks OK.
Hmm not liking the sounds of this, I'll throw a new Dipaco on it for shits and giggles but my gut is telling me otherwise.
Any thoughts?
Cheers
Nobby
Any thoughts?
Cheers
Nobby
