toddlnrd
My first diesel!
Replaced the radiator and the water pump and finally have no leaks, but I have a P0118 engine code. I replaced the temp control sending unit, but still have the code.
What am I missing? When I was working in the truck, I had the batteries disconnected for a while. Does that have anything to do with the code?
The dash temp guage reads correct, but the Scanguage plugged into the ODB II port is reading 40 degrees F no matter what (did drop to 39 once). Engine idles at 800 rpms now at normal operating temp (per dash guage).
Any thoughts?
Thanks,
Todd
Any thoughts?
Thanks,
Todd
