When its cold outside, 5-0 Celcius (not F) my truck will cycle the grids on every start even if the coolant temp is 195 (which it is all day) I have replaced the IAT sensor and there is no change, I think its unnecessary alternator load, and wondering if anyone else has this issue.
My choices are instal a switch either on the signal wire to the Grids relays (which will trip a code no biggie) or leave a hi-amp switch under hood and use it to sever the connection on the ground or the hot side
My truck is a courior rig and gets started and stopped likely 50-100 times a day, on a normal DD I dont think its an issue, but in my case that is unnecessary load, and also runs the risk of having the grid relay stick and placing a 200amp load on the alt and batterys, not to mention electrical fire risk
