chessie 6.5
2005 Duramax. When coming to a stop at a traffic light, the brakes fade at about 5 to 10 MPH. No lights come on on dash. Fluid ok.Work normally every where else. Had a couple close calls.
Ever change the fluid? First thing I'd be doing!
X2 what he said:agreed:The front ABS sensors have rust jacked and need to be removed and cleaned. The reason that it wont stop at low speed is due to the sensor losing signal with the tooth wheel and the ABS system dumps pressure from the front brakes since it thinks they are locked up. That year was included in the recall where dealers would remove them and clean the mounting surface so they work properly.
I remember the recall too.
