I thought it was dynoed probably on an engine dyno If it was calculated I feel suddenly better about my 6.2. I experimented with pop pressures as high as 4800 psi looked awsome on the tester the truck would not start hot, once running it seemed smoother, top end was also better ,was curious of injector line pressure so I brazed a fitting onto an old injector line and hooked to a 5000 psi liquid filled gauge, using 3/16 brake line ,cranking pressure was never near enough for my 4800 psi pop pressure to start hot, we reved it a couple times and pegged the gauge, ruining it, this was with marine nozzles, and .370 pump plungers, DO NOT TRY THIS AT HOME ,IT WAS NOT A SAFE TEST luckly nothing happend , my brazing didnt even leak, you should have seen and heard that brake line rattle,and vibrate. Im running 1500 psi pop pressure now account of loose pump and plungers.
